Over the last couple weeks several issues have popped up. The first was a starting issue. The boat seems to start ok sometimes and very poorly other times. It seems to start better when all other electrical systems are off. This makes me think that the problem could be a wiring issue. One time it would not start, but after fiddling with the connections it did eventually start. When running the boats voltage level is at around 11.5 volts (lower than I expected).
Another issue is power. Sometimes the boat has decent power, and other times it struggles to plane out. This makes me think there is a problem with either the carburetor, fuel filter, ect. Even when running ok, it seems to not have the power it should (Takes about 10-15 seconds to pull a wakeboarder up to 20-23 mph).
Could these problems be related? Are my initial thoughts on track?
Any help would be appreciated. Thanks, Eric
