First i just wanna say hi and i'm a new user here. I've been searching around for the past hour or so but havent really found what i'm looking for. I have a 2005 211 TE. We picked it up a few years ago and its been overall a good boat but the last few summers we've been getting more and more problems. We have taken it to the dealer several times but the never seem to fix anything so we have given up on them. Especially since we keep the boat 3 hours away and its a PITA to take it back and forth.
Anyways.. the main problems we've be having that the dealer hasnt been able to fix are with the ballast system. 1st the port side pump is not working and sounds like it is shot. 2nd, the starboard knob to open the valve has broken several times and the dealer has tried to fix the issue and finally replaced the entire cable assembly. now it is easier to turn but i guess in the process they screwed something else up because now niether the port or starboard side shut all the way and they fill with water when we dont want them too. Now from searching around i've found some people are up grading the valves with ones from flow right or th marine. Would this help fix my problem? Also, i know it would take some work, but has anyone ever converted the valves over from a manual one you have to turn by cable to electric ones the open and close just by a switch?
Hope you guys can help, i'll keep searching too and see if i can come up with anything more.
