Hi,
New member here with a question on setting the initial ignition timing on an APEX 5.7 engine in a '98 Nautique. I just installed a fresh long block, and was wondering if anyone here has the procedure for setting the timing when the distributor is dropped back in?
I had the original engine at TDC on the number one cylinder compression stroke, and carefully marked the distributor body to intake manifold relationship. I also marked the distributor rotor position prior to removing the distributor from the original engine. This got me in the ballpark, (engine starts and runs fine), but I understand there's a procedure for correctly setting the "base" timing....since the engine ECM actually adjusts the timing on the fly while running.
The timing spec is in the owners and engine manuals, but the procedure isn't listed.
Anyone?
Thanks!!
Anyone?
Thanks!!
