First off i bought a new mirror mount for my tower and the hole size is to big. i was thinking of making some sort of rubber insert to take up the space. Any suggestions? I was thinking along the lines of a tube for a bike tire.
Then i get the boat off the trailer and everything was running well then we go to leave the no wake zone gave the boat some throttle and the motor killed and couldn't get it started back up. i cracked the fuel line at the injector rail and turned the motor over and no fuel. I then cracked the line going from the fuel pump to the fuel/water separator, cranked the motor and got the same result (no fuel). So with that being said i believe it's clear that my fuel pump is bad. Is there anything else it could possibly be other than a bad fuel pump? i think if the fuel filter was plugged I'd still get some fuel going through the system?.?. I'm just wondering if there is something else i should look into before buying the $120 fuel pump?
