Just wanted to get input from anyone who has installed a Zero Off on a 206. How did you run your wires for the GPS antenna, particularly on the port side. I was considering running the wires through the engine vent ports on the bow, then down the inside of the walk through panel then underneath the bow section floorboard. Any ideas on how to affix the wire to that wall panel? What is the trick to getting that floorboard piece out in the bow section? I need to replace that piece anyway since it is partially broken.
