Removing Floorboard in 206
  • causewayskiier
    • Mar 2006
    • 101
    Has anyone removed the floor section in the bow of a 206? What is holding it in? Any tricks to getting it out?
  • Quinner
    • 2246
    • Correct Crafts
    RE: Removing Floorboard in 206
    On my 05' I believe the floor of the open bow area is all fiberglass, don't believe it is removable. What are you trying to do?
    • causewayskiier
      • Mar 2006
      • 101
      I'm trying to do two things, First the floorboard was broken by the previous owner and I'm trying to replace that piece. I have the piece just need to get the old one out. Also I am installing Zero Off Cruise control and am thinking of running the wires to the GPS antenna underneath the bow floorboard.
      • AirTool
        • 4049
        • Katy, Texas
        I've noticed the floor of my 206 under the filler cushion/in front of the bulkhead is very soft. It is obviosly not a structural member. Can't tell if it is part of the drop in liner or not. I've worried about a fat guy like me breaking it.
        Please let me know what you find out.
        • sodbuster88
          • Nov 2008
          • 368
          • Clayton, NC
          If it is anything like the 216, I had mine (under the filler cushion) replaced on warranty...it started to curl up a bit around the edge and felt spongy. The dealer removed it. I believe there are screws that hold it down and they are hidden in the carpet. See if you can find some srew heads in your carpet.
          Peace..
          • sodbuster88
            • Nov 2008
            • 368
            • Clayton, NC
            Or you can just call Dan Jackson (Extreme Powersports (Greenville, IL)). They did my work and can tell you exactly what to do.
            http://extremepowersports.com/
            Peace..
            • AirTool
              • 4049
              • Katy, Texas
              I wonder if a shop could glass a 3/4 or 1" backer on it to give it some strength/stiffness.
              It clearly is not stiff enough in my opinion.
              Causewayskiier - can you post a picture of the part?
