Update: took a better look at the jack. There appears to be a larger than normal Allen screw that I can loosed and adjust the height. I'll let you know after I go to the store and get a wrench. If this works, that Jack will be the Mack Daddy!
JMO - On my 02 Ramlin I had the standard jack....but the mounting "box" was itself bolted to a welded 3 sided piece on the trailer that stuck out about 1/2 inch....did yours have this? also - do the u-bolts interfere with the folding tongue?
Originally posted by patolocoJMO - On my 02 Ramlin I had the standard jack....but the mounting "box" was itself bolted to a welded 3 sided piece on the trailer that stuck out about 1/2 inch....did yours have this? also - do the u-bolts interfere with the folding tongue?
Once it was on the bolts weren't in the way, though the bolts that came with mine were a little to long as the ends aren't threaded all the way, so I put some brackets on there to act as spacers - you can see them in the picture I posted. Ideally I would call up Fulton and get more properly sized bolts, but it works just fine.
JMO2018 Ski Nautique 200 TE, H6
I mounted mine on the trailer right behind the welded bracket where the other one was. I went to Lowes and bought some correct length U-bolts. And the allen screw worked wonders (had to loosen the crank also), it's high enough now.
Originally posted by bscott View PostI had to replace the trailer jack on my Ram-lin trailer last year, because I could hardly crank it up/down. Took it apart and the gears looked fine. I ended up ordering a replacement from Mid-Ohio. The replacement was a Bulldog rated at 1500# and an exact fit. Recommend calling your local shop and ordering a new one.
