I have a2001 Super Air with a buzzer under the dash panel going off, as soon as I power up the ignition. It taps power off the fuel gauge and is red buzzer. Does anyone know what this buzzer is for and how to make it shut up without dissconnecting it?
Drain plug has a sensor attached to alarm(buzzzer)
I figured out the problem the other day, when I was checking my fire extinguisher(not related). I didn't have a problem at all just a sensor that I was unaware of doing it's job. The drain plug has two wires going into it that will sound the alarm, to inform you that the drain plug was not installed. Great idea, but I was not aware the boat had this feature. I guess it should though for how much I paid for my Nautique. Everytime the buzzer or alarm sounded it was when the boat was in the garage on the trailer with the drian plug removed, while the ignition was powered up. PROBLEM SOLVED! Please tell others so they don't spend weeks testing wire and sensors, trying to figure this out like my father in law and I did.
