Purchasing traction padding on gunnel of SAN's???
  • Jarabacoa
    • 40
    You can get this from your dealer and it's around $12 a strip. I just found out that 3M makes it.
  • JWAT
    • Feb 2004
    • 527
    • NE Indiana
    • 1997 Super Sport/Super Air Nautique 2008 Super Air Nautique 210
    Does anyone know if you can purchase the traction padding that is on the gunnels of the Super Air's? You know, the pads that you step on when getting the wakeboards off of the tower. If so, I assume from a dealer? And does anyone know how much it costs? I would like to get some for my Super Sport if at all possible. Thanks a lot.
    2008 Super Air Nautique 210TE
    • Luke
      • Mar 2003
      • 509
      • Des Moines, Iowa
      You might check out Gator Grip:
      http://www.wakejunky.com/
      • JWAT
        • Feb 2004
        • 527
        • NE Indiana
        Yeah, I used gator grip on my last boat and thought it worked really well. I just wanted to get the OEM stuff if I could. Plus, I don't need as much as gator grip sells on their site.
        • wakejunky
          • 679
          • Ca
          • 2003 SAN
          Actually you can get a 14" x 2.5' (2.5 feet) piece for $30.95 delivered which will give you more than the stock pieces would for $24.
          Chris
          • JWAT
            • Feb 2004
            • 527
            • NE Indiana
            But I only need 2 small strips about 3" x 12". . .so $24 is cheaper than $30.95 . I'm not putting your product down at all wakejunky, because it is really good stuff. But, I just need two small strips and if I can get the OEM stuff, then that makes it all that much better. Thanks for the advise everyone. Hopefully it's only $12 a strip. I figured CC would gouge you for like $30 a strip or something. I'll be giving a local dealer a call soon.
