Hit the lake this afternoon after work. We wakeboarded for a few hours and were doing some wakeskating when my '00 SANTE started acting up. The check engine light came on and the boat seemed to surge or lose power if any throttle was given. Oil preasure was fine and so was the engine temp. Gas guage read a little over half a tank. I shut the engine off, let it sit for 10 minutes, and then restarted. Same problem. We then idled back to the ramp and loaded the boat. Check engine light stayed on the entire time and would flicker like it wanted to turn off.
Any idea what is causing this? I read several of the other posts regarding the surging problem and they all mentioned fuel pressure but none of them mentioned a check engine light. The check engine light has me worried that it is more than just a low presure fuel pump issue.
Thanks for your help.
Paul
Paul
