Need a little help
I have a 1996 5.8 GT-40 with only a 160 hours. It started at the end of last summer. You would be going a long and the engine would cut out and start right back up. This summer the problem progressed to after running for a bit, the engine would cut out, now it will not start back up until after cooling off. When you turn the key a few times the engine tries to start but will not. After some research on here I think it is the high pressure fuel pump. Can some one point me to a thread that show’s how to test or replace the high pressure fuel pump. I have already changed the fuel pump relays. Thanks for the help
