Not too sure what this sensor is? ANY help would be greatly appreciated. Engine has not yet entered "limp" mode.
sorry, reading your messages but have no clue , always like to read explanation and remedies for future reference.2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
I have a 2008 Sante 210 & had a problem with a sensor my first time out 3 years ago but I can't recall which warning message showed up. The boat ran great & all guage readings showed normal but the warning beep was very annoying...I recall my dealer replacing the gateway under warranty.
In the owners manual it shows a MAN AIR SENSOR SEE DEALER as being a (maniflod air temperature sensor malfunction).
It is the air temperature sensor in the intake manifold. this is one of the many sensors the computer uses to calculate the amount of fuel to run into the engine. When you first start the engine, the computer compares the reading from this sensor to other temperature sensors, and if it finds a discrepancy, it sets a code.
look for the sensor. I would tell you where to look, but I only have a GT-40 engine. Make sure the wire is hooked up to it. Beyond that, you probably need to go to a dealer.
