Appropriate Voltage for Batteries
  • gmtkyfcs
    • Jul 2005
    • 10
    I have a 95 SS. What should the voltage be for the deep cycle battery as well as the stereo battery? Right now with a voltage tester I am getting readings of 12.5v.
    My dealer said anything below 13v is not good.
    Also, is it correct to have the pelco switch on 1 and 2 or should it just be on the deep cycle?
    Any help would be appreciated.
    1995 SS Nautique
    Houston, TX
  • AirTool
    • 4049
    • Katy, Texas
    RE: Appropriate Voltage for Batteries
    Are you talking about engine running or not?
    Without the engine running...I've not seen a lead acid 12V battery at 13 volts or higher.
    A chemist will tell you fully charged is 2.13 V/cell x 6 cells = 12.8 V
    • gmtkyfcs
      • Jul 2005
      • 10
      Re: RE: Appropriate Voltage for Batteries
      Turns out that wires were cut and never replaced/reconnected. Being a novice here when it comes to self repairs i thought it would be best if i just made a short video to show the problem.
      If anyone can help i would greatly appreciate it.
      http://gallery.me.com/gmtkyfcs#10001...;bgcolor=black
      If this link doesn't work please try this one.
      http://www.youtube.com/watch?v=QP3pUIzo4mc
      1995 SS Nautique
      Houston, TX
        RE: Re: RE: Appropriate Voltage for Batteries
        No electrical load, engine running above 2000 RPM, 13.5 to 14.5 volts, at the battery.
        • AirTool
          • 4049
          • Katy, Texas
          If the engine off / no load voltage is less than 12.0, thae battery is fully discharged or bad.
          To properly check for a bad battery, it needs to be fully charged then load tested.
