90 Sport Nautique points replacement
  • Kevin_B
    • Jan 2008
    • 313
    • Greensboro, NC
    • 2008 SANTE 220 1990 Sport Nautique
    Replaced the points on a 90 Sport Nautique with a ford 351 Prestolite distributor.
    Gapped with gapping tool, boat runs ok, but I can't get a good dwell reading, any thoughts??
    1990 Sport Nautique
  • SNobsessed
    • Nov 2008
    • 60
    RE: 90 Sport Nautique points replacement
    Kevin - Just carefully gap them to .018 inch. Make sure the rubbing block is centered on the cab lobe. Use .018 & then try .019; .019 should have alot of drag. The dwell meter is just a confirmation of correct gap setting, as it is a much more sensitive gage.
    Also, if your timing is still right, you know you nailed it.
    It is a good idea to add some cam lube too.
    • Nautiquehunter
      • Jun 2008
      • 2080
      As SNobsessed said and make sure the rubbing block is lubed with cam lube it must be set on the high point of the distributor cam lobe. If you have a dwell meter connect it to the negative side of the coil and ground it should be set on 8 cylinder and should read about 30 degrees. Check timing after points are set any change in point gap will change the timing.
      • AirTool
        • 4049
        • Katy, Texas
        Be sure also to put a new condenser.
