Spinner racks keep slipping!%$#@*
  • sjames
    • May 2009
    • 219
    • California
    I have a 2006 SANTE with FCT and stock spinner racks. They keep slipping when loaded with boards and under way. I took them apart and they seem to be held in place with two large o-rings? I cleaned everything and reassembled but the left side keeps slipping.
    No grease and the rings looked like they were in great shape. Any advice?
    Do the right thing.......
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    RE: Spinner racks keep slipping!%$#@*
    Cut a piece of bike inertube - and put inside the mount - this should tighten up the fit.
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • sjames
      • May 2009
      • 219
      • California
      Thanks but is the o-ring on the inside of the spinner hub. The pin stays lock but the whole inner hub slips. I am not sure I can get a piece of rubber in there? I know what you mean for the other stuff on the tower, Bimini, mirror, speakers etc I have that.
      Thanks for the advice though, I'm taking them apart one more time to see if I can figure it out.
      • wake4life6
        • Mar 2009
        • 218
        • Olympia, Washington
        Hope mine don't do that anyone else have that problem?
        2006 210 SAN! TE
        • Chad52
          • May 2004
          • 295
          • Huntsville, AL
          • 2008 Super Air Nautique 210 2003 Super Air Nautique Team 210 2001 Super Air Nautique Team 210 1999 Super Air Nautique 210 1994 Mastercraft Prostar 190 1992 Manta Ray 189 Sport
          Just noticed this post. I'm having the same problem. Anybody got a fix? I have a call in to CC Customer Service and my dealer has never heard of the situation happening with the Nautique racks...
          Chad
          • Boardboy
            • May 2009
            • 39
            I am not familiar with the spinning racks but I have held all my board racks in place by drilling a hole through the clamp and the tower and using a stainless set screw or two to keep them in place.
            I don't know if this will work on the spinners. Just thought I would mention it.
            • SuperSquirt
              • Apr 2008
              • 534
              • Tennessee
              • 2008 SANTE 210
              If you have the spinner racks that uses a T-shaped pin, then they might just need to be tightened using an allan wrench. Inside of my 08 Titan racks, are two rubber o-rings, and you are supposed to smear grease on the inside.
              • sjames
                • May 2009
                • 219
                • California
                Thanks for the feedback still having the problem, will take the apart one more time and a tighten of he inner clamp. Titan cust
                has not responded.
                • xrichard
                  • Aug 2008
                  • 669
                  • El Dorado Hills
                  • 2023 G23
                  Did this ever get resolved?
                  I have the same issue with the Titan OEM spinner racks on an 08 210...the clamps are not moving/slipping/rotating, but the spinner part of the rack releases and spins into the boats when loaded with boards (...if we hit a wake or are in anything but very smooth water). It can be a bit dangerous as the boards are eventually going to hit someone if I use the rack.
                  Previous boats:
                  2015 G23
                  2008 SAN 210
                  2002 XStar
                  1995 Sport Nautique
                  • sjames
                    • May 2009
                    • 219
                    • California
                    I called them and got what was their last set of o-rings and spare parts. I have not re-built them yet but will post once I do.
