Rough idle and stall on start up when hot
  • benwa43
    • Aug 2004
    • 19
    • South Carolina
    I have a 2002 196 with the gt-40 (350 hours). The boat idles very rough and sometimes stalls after it has been sitting for 45 minutes + after being run. If it stalls, it will start right back up but will idle rough and may stall a second time. It also smells like it is running rich during this rough idle/stall period. This only happens when the boat is hot, say after pulling 3 skiers in a row and then letting the boat sit at the dock for a while. Once I give it some throttle the idle will smooth out some and then once I give it throttle to pull the skier up the boat will operate fine. This problem seems to be getting progressively worse.
    I have performed the following:
    New fuel filter
    New temperature sensor
    New cap and rotor
