Hello everyone,
I have a 2004 216 TE with a 330 Excalibur PCM.
Like always, I changed the impeller at the beginning of this season and have been experiencing randon overheats at idle. It will rise above 175 then I'll throttle up and start moving, then the motor cools back down to 160 or so. It does not get hot while we are moving.....seems to run at around 160. Also it does not get hot at every idle but it still does it often. Its heated up at idle about 5 or 6 times over the last 4 hours of operation.
Its never done this before. Any ideas on what to check?
Also, can anyone tell me what normal operating temp should be?
Thanks!
Thanks!
