I have a 2002 sante and have no power at the keypad to turn on boat. Used volt meter and it seems to have power going every where but I can not get the keypad to work. Has anyone had this problem? It did it a couple of months ago and then just started to work so im confused, and it is doing it again.
Did you look behind the master kill switch (On, Off, Bilge Only) to make sure there aren't any loose connections? take the screws out holding the kick panel in place and look behind it, mine had come loose at one point.2018 Ski Nautique 200 TE, H6
I had a power issue recently doing a re and re on the stereo. No power to the master switch, dash keypad or anything. I have a 2001 SN 196. There is a fuse holder right by the battery terminal with a 20 amp fuse in it. It was blown. Popped in a new one and everything works. Check that. It is easier than climbing under the bow to get at wiring etc.
I just had this problem a couple weeks ago. It was the master toggle switch (all on, off, bilge only). The all on connection behind the switch had broken off...just had to replace the switch.
See this thread...
http://www.planetnautique.com/index....ic&t=14865Current: 2017 G23
