2001 SAN GT40.. "do not operate" dash light
  • adkinsbj
    • Apr 2006
    • 20
    • Huntsville
    The dash light "do not operate it the light does not go off over 1200 rpm” will not go off... I have checked all the fluids, they are all at the correct level. Everything on the boat is working properly. What else is connected to that light???? What else can it be?? All the gauges on the dash are reading the same as when the light was not staying on. It will under acceleration blink off but once I’m on plane it lights up again...
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    RE: 2001 SAN GT40.. "do not operate" dash light
    That is for your trans fluid. If everything is as it should be fluid-wise, you may have a bad sensor. Fairly cheap fix if you are sure on the rest.
    the WakeSlayer
    1968 Correct Craft Mustang
    • triplered
      • Jan 2005
      • 31
      • Ramsey, MN
      • 1986 Ski Nautique 1996 Ski Nautique 176
      Actually, I believe the light is for the v-drive. Check the v-drive fluid level. It is underneath the center cushion of your rear seat. My bet, the v-drive fluid is low or the sensor is bad. Good luck.
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        Correct, th V-drive is what I meant, sorry.
        the WakeSlayer
        • AirTool
          • 4049
          • Katy, Texas
          I thought the light went off with higher fluid pressure. So maybe the pressure is low of the sender is plugged/bad.
          • adkinsbj
            • Apr 2006
            • 20
            • Huntsville
            thanks.. i am going to change the fluid later today or this weekend
