Bow lights won't come on?
  • dcstack
    • Jul 2009
    • 4
    I have a 2007 crossover sv211- none of the breakers are popped and for some reason I can't get those lights to work. Ideas?
    2004 SV 211
    Winter Park, Fl
  • Fatboy206
    • 36
    • Dubai, UAE
    Check out the bulb contacts, sometimes the bulb loses contact with the little spring in the holder due to a bit of corrosion or simply the contact spring may have lost a bit of tension. You might want to apply a little grease to the contact surfaces to prevent future corrosion. If you are going to fiddle around and adjust the contact spring tension a tad you should make sure you have the power supply to the lights off to prevent sparking and some resulatant damage.
    • dcstack
      • Jul 2009
      • 4
      Thanks Fatboy, I actually got them on last night. Thanks!
      2004 SV 211
      Winter Park, Fl
      • dcstack
        • Jul 2009
        • 4
        So I got them running but now non of the lights on my port side are working: this includes bow, walk through and plat form lights.
        Weird?
        None of the circuit breakers are popped?
        Any help would be appreciated...
        2004 SV 211
        Winter Park, Fl
        • dcstack
          • Jul 2009
          • 4
          nothing ?
          2004 SV 211
          Winter Park, Fl
