My buddy went to pull me up today and the throttle would not work. It would go into gear but not speed up. I looked at the back were the throttle cable is. It is threaded and has a brass fitting that looks like it had wire on the end that broke. It looks like to me that the cable form the pp runs to the leaver on the throttle itself mounted on the bracket and had the piece with the wire that was connected to the fitting that went on the end of the throttle cable. Anyone know where I could get one. I think it is going to be the black cable that goes from the pp to the throttle. Thanks
Tags: None
RE: 2001 210 throttle cable
www.perfectpass.com
(902) 468-2150
Give them a call, they will sell you exactly what you need.
