I dropped my Nautique in the water Saturday. It is a 92 with carbed 351 and the electronic ignition from PCM. It warmed up fine and went from the marina to my house without problem. ( It was running about 20 minutes) I went to ski after leaving it sit for about 45 minutes. I notice that it idled poorly. (about 750 in neutral - 500 just in gear) It also picked up a vibration at about idle speed and it would quit at about 1500rpm.
I know I did not hit anything with the boat. The prop looked fine. There was nothing wrapped around the shaft. Tranny fluid was ok too. We have been having carb problems, so I wonder if this could be a related problem? Any thoughts?
Eric
Eric
