I plan on ordering PP Wakeboard Pro next week. Does anyone have pictures of their install of the paddle wheel? I want to get the location right. Also, can you use 3m 5200 fast cure to seal it? Thanks.
You can follow some things in my thread. Look in my sig. Remember though that I have a Super Sport V-Drive.
Originally posted by wake_funYou can follow some things in my thread. Look in my sig. Remember though that I have a Super Sport V-Drive.Previous:
2011 Super Air Nautique 210
1994 Sport Nautique
Originally posted by mf01Originally posted by wake_funYou can follow some things in my thread. Look in my sig. Remember though that I have a Super Sport V-Drive.2001 SAN
Look at pic DSCN3521_small.jpg here: http://www.planetnautique.com/index....pic&t=2949. It looks like it's about 12" in front of the RWI.Previous:
1994 Sport Nautique
Keep it well away from any water intakes. 12" should be ok, but the PP does disrupt the water just by being there. Also, measure 8 million times before you drill that hole. Then double check it. 5200 is a good choice on the sealer, that stuff is great.the WakeSlayer
1968 Correct Craft Mustang
All the pictures I've seen of the installs show it on the port side, the same as the RWI. I don't believe I have any water intakes on the starboard side, why not put it there?Previous:
1994 Sport Nautique
No reason. Put it where you have room to work. I cannot remember who posted the magnet trick for lining up your hole in a good spot. Try a search, it may have ben Wake_fun.
Measure, measure, measure, double check, then drill.the WakeSlayer
Why get the paddle wheel version at this point? Why not the stargazer? Personally, I still think an RPM pull is the best anyway, even for wakeboarding.Now
Originally posted by ChexiWhy get the paddle wheel version at this point? Why not the stargazer? Personally, I still think an RPM pull is the best anyway, even for wakeboarding.Previous:
1994 Sport Nautique
- Apr 2005
- 1407
- Discovery Bay, CA
- 2001 Super Air Nautique (Current) 1998 Ski Nautique (former) 1982 Ski Nautique (Current)
Originally posted by mf01Originally posted by ChexiWhy get the paddle wheel version at this point? Why not the stargazer? Personally, I still think an RPM pull is the best anyway, even for wakeboarding.
On the other hand, a paddle wheel does not compensate for speed of the water. The paddle wheel only registers how fast the boat is passing over the water.
I haven't used a water ski version of perfect pass in a long time, but I thought it had a function to enter estimated water speed in attempt to help compensate. ICBW.
BKH2001 Super Air
There were a few discussions about this at the time that the GPS systems were coming out. IIRC there were patches for the Zero Off to compensate for this. Given that, my opinion is that if you are in a lake part of the river the flow is greatly reduced so you should be fine with whatever you choose. I could very well be wrong too, but do a search on older discussions abuot Zero off, and Stargazer. That or simply call them.the WakeSlayer
Originally posted by bkhallpassOriginally posted by mf01Originally posted by ChexiWhy get the paddle wheel version at this point? Why not the stargazer? Personally, I still think an RPM pull is the best anyway, even for wakeboarding.
BKHPrevious:
1994 Sport Nautique
