Newbie here,
I have a 93 Sport Nautique that I have owned and loved for 4 years now. It has the ProBoss 351 HO with the Pro-Tec ignition and Holley carb.
I did the usual plugs, oil change and impeller at the beginning of the year and got 3 great morning runs out of it. On my 4th trip out, we pulled away from the doc and it ran fine until we hit exactly 2400 rpm and then the motor ran like an out-of-balance washing machine. Regardless of how much gas I gave it, it just got worse. I put my tail between my legs and loaded up and went home. I pulled the plugs and they were black after only 8 hours of running. Carb is too rich which I knew since this is a CA boat running in Utah but I ran plugs all last year with NO fouling at all. I replaced the plugs again, thinking I might buy time but to no avail. Still hitting the 2400 rpm barrier and it is exactly the same every time. I have not messed with timing or anything else, yet...
Anyone have any ideas? It starts and seems to run perfect right up until I hit 2400. Carb gone bad? (Holley 4bb) Ignition problem? I just want to get back on the water. Any ideas or help would be greatly appreciated. There is a long back log at the boat repair shops and I am a DIY'er anyway. Thanks.
Ladd
Ladd
