Tightening the throttle
  • sperbet
    • Aug 2004
    • 283
    • Truckee, CA
    Does anyone know if you can make adjustments to the throttle. I just got a 95' Super Sport and the throttle seems to be a little lose. If you hit some chop the throttle will fall back into the up position and the boat will slow all the way down. It seems that if I could just tighten it up this would not happen.
    Ummm, I\'ll take the REAL 210 please. Thanks.
  • mrese
    • 67
    SKI DIM sells a cable brake for $15.56 if your boat doesn't have one. If it does you can simply adjust the screw to your comfort level.
