I posted this awhile ago, but didn't receive any responses.
I have something weird going on. On the right keypad, the ballast tank "empty" button will work and the pump comes on. The "fill" button lights up, but the pump will not come on. ( The pump is fine because I removed it and hooked it up directy to a battery and it ran fine.
Also the shower appears to be on all the time because it is leaking water around fittings. The button for the shower will not light up and will not cut off the shower.
Any suggestions other than replacing keypad. This keypad was replaced three years ago.
I really would appreciate any response, Thanks very much
