01 210 keypad help
  • boutwell_43
    • Jul 2009
    • 53
    • Pace, Florida
    01 210 keypad help
    I have a 01 210 that my problem is that the keypad where you put the code in is not working. The blower fan will work and the horn and bilige but the numbers will not. It had two batteries, I replaced one of the batteries and it had not worked since. I called the dealership I bought it from and the parts guy told to check the fuse box. I did and everything was good. He told me that he does not know what to tell me and pretty much silence over the phone. This is my first nautique, I asked him if the keypad had a master reset that when I disconnected the battery it could have reset the code. But he said he did not think so. Any info would be great, just got an new prop and ballast really wanting to get on the water. Thanks
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    RE: 01 210 keypad help
    As it is Saturday, I would just start searching on the topic.
    I think I read something about the codes after a battery swap, but I could be wrong.
    Here are a couple things to check.
    http://www.planetnautique.com/index....ht=keypad+code
    Good luck.
    the WakeSlayer
    1968 Correct Craft Mustang
    • MNSuperAir
      • Sep 2005
      • 591
      • St Paul
      • 2016 SAN 210
      It is not a problem with removing the batteries. I leave my batteries out of the boat all winter and in the spring when I replace them I only have to input my code. Not the master code.
      I have heard stories of the pads failing and needing to be replaced. Hope that isn't the case.
      2016 SAN 210
      2006 SANTE sold
      2001 SAN - sold
      1991 Sport Nautique - sold
      • boutwell_43
        • Jul 2009
        • 53
        • Pace, Florida
        Well I done the only thing to do. I ordered a new keypad, I cant believe they cost that much. I ordered it from white lake marine, they helped me out some. Really nice people, had no problems and it shipped out right after I ordered it. Hope this works.
