2004 SANTE 210 stalling but not going dead
  • itssh0rty
    • Aug 2009
    • 2
    I am having problems with my 2004 210 stalling sporadically, but not going dead. I thought the problem may have been the Pefect Pass, but the problem occurs regardless if PP is on or off. Best way to describe the problem is... while cruising, PP will beep and go blank (regardless if on or off), Low Voltage light appears (not sure if it does this every time), dash lights go blank, boat stalls (but doesn't go dead), and then a secord or two later everything regains itself and the boat resumes normally. Also, PP (while off) will beep and reset itself while cruising but not affect the boat performance.
    It sounds like a low voltage problem (obviously), but the boat cranks instantly every time. I am running dual batteries and have traced wires as far as possible but haven't found any loose wires. Has anyone had similar problems? I found a few threads, but no real solutions. Thanks!
