simple ? about 12V
  • natetnc
    • Jul 2009
    • 29
    simple ? about 12V
    12V doesn't work, i am assuming it blew a fuse but don't know where the fuse box is located in a 1997 sport nautique GT40. If the fuse is not the problem i will go from there but that will be the first check.
    -nate
  • natetnc
    • Jul 2009
    • 29
    seriously, no responses?
    • d_nodixon
      • Sep 2008
      • 475
      • Hammond, LA
      • 2013 SAN 230
      when my 12v did not work it was b/c of loose connection (06 210)
      2013 SAN 230
      2006 SSN 210 (SOLD)
      • AuMDLST
        • Apr 2007
        • 870
        • Orlando, FL (Butler Chain)
        Possibly the lack of details is causing the answer issue.
        12 volts where does not work? Stereo? Dash? 12v acc outlet? Amplifier? Starter?
        2006 SANTE 210 (Pending Sale)
        2005 206 TE (Previous)
        • Sinkoumn
          • Jun 2006
          • 578
          • MPLS - St. Paul, MN
          • Super Sport Nautique
          Is your battery dead? Yellow_Flash_Colorz:
          Definitely give more details on the problem for better help with the issue.
          Neuston Boards
          Nautiques
          • natetnc
            • Jul 2009
            • 29
            sorry, the 12V cigarette lighter
            • 2004196
              • Dec 2007
              • 162
              • University Place, WA
              • 2006 196LE
              Acc outlet
              Corrosion, wire off? Have you tested the wires leading to it to see if you have power just prior to the outlet? Start with the obvious (easiest) and work backwards. If all else is working I would lean to corrosion or a loose wire.
              Good luck
              2004 196 LE Black/Grey
              330HP Excalibur Water Churner
              2002 Grey F150 Harley
              475+HP Supercharged Tire Burner
              • BT
                • Dec 2008
                • 77
                • Alabama
                • 2012 Super Air 230 1997 Super Sport sold
                RE: Acc outlet
                My 12volt receptacle on my 97 super sport is powered up by the accessory 1 circuit breaker (the push button panel next to the key). That is the "fuse panel" so to speak. You can always pull the dash panel back and follow the wires from it. I bet it goes to a circuit breaker.
                • natetnc
                  • Jul 2009
                  • 29
                  checked the wiring, it is connected and doesn't look corroded. guess i will buy something to check voltage prior to connection. didn't know if boats had a panel similar to cars where i could easily switch out the fuses, guess not.
                  • Rick
                    • Mar 2004
                    • 1250
                    • San Diego, Ca
                    There aren't fuses but a breaker box. In 2000 itr was on the kick panel at the drivers feet. They are push type breakers with silicone covers.
                    Nautiqueless in San Diego
                    • 8122pbrainard
                      • Jul 2007
                      • 255
                      Get a inexpensive volt/ohm meter. You'll find it real handy for troubleshooting and won't becaome simply a "parts changer". They come with instructions for basic testing.
                      If you get the 12 volt nominal to the backside of the lighters socket, them ohm out the lighter itself. If open then it's simply a burnt out element.
                      Keep in mind that breakers don't pop and fuses don't blow without a reason. Check with the meter before you reset a breaker or put a new fuse into any circuit.
                      • harddock
                        • Apr 2008
                        • 292
                        • toontown E-9
                        Make sure the item your plugging into the 12v works. Sometimes the plug end is the problem.
