Need help! Thanks...
  • TRBenj
    • 1681
    • NWCT
    Originally posted by Mikeski
    Call me crazy but before I went to the trouble of pulling the trans I would just fill it with fluid and run it with the tube in there. Might get chewed up, might cause troubles, might clog up the trans, but it might not.
    I think youre crazy. :razz:
    I had a similar issue a few years ago. Instead of going straight down the dipstick hole to the bottom of the case, the tube got diverted off to another hole in the side. I kept pushing it further in, wondering why my pump wasnt drawing fluid. When I got a light and saw what had happened, it was too late- it was snagged and would not pull back out. In talking to a few tranny experts, they suggested I pull the trans and get it out rather than run it- so thats what I did.
    No need to rebuild while youre in there, but do inspect everything. If it looks good, button it back up. If not, send it out for a rebuild- but pulling the trans is not a hard job at all.
    1990 Ski Nautique
    NWCT
    • ltk
      • Sep 2005
      • 17
      • Warner Robins, GA
      Mikeski, definitely true... worst case scenario I trash it and end up having to rebuilding it regardless. I'm sure there are some mechanics out there cringing at the thought of this. Luckily it isn't too large of a lake where I'll be stranded in the middle of no where. I'm sure I'll at least get a couple solid pulls out of it
      • ltk
        • Sep 2005
        • 17
        • Warner Robins, GA
        So if I pull the transmission, by unbolting it from the engine block... will I be able to access the tube inside? It appears the transmission is in two pieces. I'm about to take a photo and post it. brb
        • ltk
          • Sep 2005
          • 17
          • Warner Robins, GA
