2001 Air Natique GT-40
  • motoxx
    • Aug 2009
    • 1
    • Auburn, California
    I am working on friends boat, it cuts out and looses power. I checked fuel preasure when it drops cyl.and it does not drop below 35lbs. I used an auto scan tool and got code 95????? Someone told me its fuel pump related. The gage says different. Can't barefoot at low speeds. wake boarding all day ok.????
  • jjgag60
    • Sep 2008
    • 165
    gt-40
    Down load the manual off this site for the Gt-40. A code 95 says it has to do with a ground on the fuel pump or fuel pump relay stuck open. The relays are only $12 each at NAPA. The manual also talks about a "wiggle" test to check for ground. Good luck
    Google ECC-iV this is the computer we have in our Gt-40's. Charles Probst has a great book on the computer and Ford Fuel injection.
