Wheel bearings, and prop shaft use of castle nuts are two different applications. On a prop shaft, the nut must remain tight. If it is not, the the contact in the taper can be lost, and the prop will move around on the prop shaft, and wear the bore of the propeller. The prop may not seat correctly each time you shift into a forward gear, and cause a vibration.
The prop must be seated on the taper. The castle nut is then installed, and turned to make contact with the propeller. The nut is then tightened further until a hole becomes available for the cotter pin. If it takes an excessive amount of torque to get to the next available hole, get a different castle nut, or flat file the back side of the castle nut.
