Hey all, first time poster here. Need some help with our 94 Nautique bow rider, not sure of the model, but Ill post when i get it. Its got a Ford 351 motor.
So. here's the problem. Boat has trouble starting without lots of gas (handle down), especially on a restart. When idling, it revs and drops almost regularly, and then finally dies. When up to speed, around 2500rpm revs get erratic, gunning up and down, and sometimes just dropping, also on turns.
Situation:
New battery, coil, belts, fuel filter
1 yr old: plugs, dist cap, rotor.
May be the original plug wires
What Ive done:
Ran full tank of gas with STP fuel treatment
Running 87 octane (not from a wet dock)
Manual says to run 89 -- IS this critical???
Cleaned the carb inside and out
Checked plugs
Had a different fuel delivery problem in May until I cleaned out the screen in the carb inlet fitting. Checked that again this morning, and its clean.
Any help would be appreciated. Cant ski
Thanks!
Chris
Situation:
What Ive done:
Checked plugs
Thanks!
Chris
