01 Air Nautique Died Suddenly
  • EchoLodge
    • Jan 2004
    • 616
    • Huntington Beach, CA
    • 99 Super Sport
    The boat has around 600 hours on it. This weekend I was driving at 40 mph for about 10 minutes when the engine went dead. All the gauges were within normal range. I checked both the fuel cell and fuel rail by depressing the valves. Gas was present. Still would not start (engine would crank). I checked all the breakers and knocked on the two relays under the engine by the 3 breakers. None appeared to have been popped. About 5 minutes into my tow home, I was able to restart the engine. The water was calm and the stereo was on and loud at the time (not that it should matter). Any ideas?
    sigpic
  • ffmedic74
    • 835
    • Lexington, KY
    RE: 01 Air Nautique Died Suddenly
    If your sure its not fuel then it theoretically should be a spark issue.
    • EchoLodge
      • Jan 2004
      • 616
      • 99 Super Sport
      Thats what I am thinking. I have a buddy that has a Tige with the merc engine. He carries relays that he has to replace almost yearly. I don't think PCM has the same issue.
      sigpic
      • BKinSoCal
        • Sep 2008
        • 507
        • Prescott, AZ
        Sorry to hear about your boat.
        I was looking at your screen name and where you live. Do you go to/have a place at Echo Lodge? I'm asking because that's where out place is...UL13.
        Brian
        BKinSoCal - Brian
        '08 SANTE 230 - Current
        '05 SANTE - Sold '10
        '04 216 TE - Sold in '05
        • EchoLodge
          • Jan 2004
          • 616
          • 99 Super Sport
          Re: RE: 01 Air Nautique Died Suddenly
          Brian
          That's me. B27. I see your boat out there a lot. Also run past your mobile in the mornings.
          Eric
          sigpic
          • BKinSoCal
            • Sep 2008
            • 507
            • Prescott, AZ
            Brian
            Eric
            At least someone is running by my place. I'm typically riding in the morning...only time we can get good water.
            We'll need to hook up next time we're both down there at the same time.
            See you soon.
            Brian
            BKinSoCal - Brian
            • EchoLodge
              • Jan 2004
              • 616
              • 99 Super Sport
              RE: Re: RE: 01 Air Nautique Died Suddenly
              Start Hydrofoiling... Then you can ski in the bad water too!
              www.foilforum.com
              sigpic
                Do this primary ignition system test:
                http://planetnautique.com/index.php?...=ignition+test
                Do this fuel pressure test:
                http://planetnautique.com/index.php?...=fuel+pressure
                That should narrow down your engine problems a lot.
                • EchoLodge
                  • Jan 2004
                  • 616
                  • 99 Super Sport
                  Re: RE: Re: RE: 01 Air Nautique Died Suddenly
                  Thanks. Do the relays below the breakers in the second picture of the fuel pressure link control the fuel pump?
                  sigpic
                    RE: Re: RE: Re: RE: 01 Air Nautique Died Suddenly
                    One of the relays supplies power to the ignition system, the engine's computer, and the coil of the fuel pump relay. The other relay supplies power to the two fuel pumps.
                    Both of the "cube" or "Bosch" relays have power applied at pin 30 of each relay, all the time the battery is connected.
                    The key applies power to the ignition/computer relay coil at pin 86 and the coil is always grounded through pin 85.
                    Power is then applied to pin 86 of the fuel pump relay. When the engine computer decides it needs to turn the fuel pumps on, the computer grounds pin 85, turning the fuel pumps on.
                    You can download the GT-40 diagnostic manual from the download section of this site.
                    • Quinner
                      • 2246
                      • Correct Crafts
                      Did you check your lanyard? That got me once after my buddy towed me in and we were on the trailer noticed it was not fully engaged.
                      • EchoLodge
                        • Jan 2004
                        • 616
                        • 99 Super Sport
                        Re: RE: Re: RE: Re: RE: 01 Air Nautique Died Suddenly
                        Good info. Do you know the napa part number? I might carry some as spares.
                        sigpic
                        • EchoLodge
                          • Jan 2004
                          • 616
                          • 99 Super Sport
                          Another good thing to check. I was able to get it restarted w/o messing with it. It was a hot day and the boat was running close to wot for 15 mins. With the engine cover up and me messing with everything I could think of I am wondering if the relays cooled and came back to life.
                          sigpic
                          • EchoLodge
                            • Jan 2004
                            • 616
                            • 99 Super Sport
                            Relay
                            http://www.skidim.com/prodinfo.asp?number=R130011
                            http://www.planetnautique.com/index....c&p=118927
                            sigpic
