Daul Battery setup
  • Onevw2go
    • 179
    • Wisconsin
    Daul Battery setup
    Does anyone here have a dual battery setup on their boat. I think that when I had some work done on my stereo, they rewired the battery setup wrong. I am OK with mechanical stuff, but electrical is a whole different story.
    Here is the deal. When the switch is in #1 or Both voltage is at or around 12v. When switch is in #2 position No reading or power at all. I thought the battery was dead, so I took it out and charged it. It was fully charged, so I put it back in the boat. same thing. So then I thought maybe it is charged, but can't hold a load... Took it in and had it load tested. Everything is good with the battery. So I am thinking the wiring is screwed up somewhere. Any ideas how I can test the system or trace back the wiring to see if something is not plugged in, or plugged into the wrong spot? Thanks in advance for any and all help on this issue.
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    RE: Daul Battery setup
    How about checking the battery switch? It sounds like you have narrowed it down to that.
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
    • CradGen2
      • Aug 2020
      • 1343
      • Horseheads NY
      Also check the ground negitive cable, is it grounded?
      • AuMDLST
        • Apr 2007
        • 870
        • Orlando, FL (Butler Chain)
        where did you get the voltage readings? Did you use a meter?
        2006 SANTE 210 (Pending Sale)
        2005 206 TE (Previous)
        • Onevw2go
          • 179
          • Wisconsin
          Thanks for the suggestions. Problem turned out to be a bad ground. Cleaned up the terminals and everything is working correctly.
