When I close the middle part of the windshield of the boat (2002 SAN) the top part of the middle windshield rubs together really tight when it is closed. Is there any way the adjust this on the top part of the windshield so that it doesn't rub anymore? The bottom part has plenty of space when it is closed.
RE: windshield too tight
There are two braces that come off of the windshield right there at the walkthrough down to the deck. On the deck end of those braces, you can loosen the screws and make small adjustments given that there are slots at the end of the braces instead of a single hole. Shut the window, loosen the screws and adjust until you get the clearance on the top and bottom, then re-tighten.2001 Air Nautique
