PCM 330 Oil Change, Surely its more than 4QT
  • bj25430
    • Aug 2009
    • 65
    • McAlester, OK
    • 2008 220 SANTE - Current - 2006 SV211 TE Air Nauti
    Changed the oil, and filter, 4qts in and it reads just below the "add" on the dipstick? I Know im not the sharpest tool in the shed but i think im a qt short? Anyone put in 5 Qt to get it to read full? :shock:
  • sstexan
    • Jun 2006
    • 230
    • 1999 Super Sport GT40, NDT 2007 236 Team
    According to my PCM 2007 manual It states that the 5.0 and 5.7 engines are 4 QTS with Filter and the 6.0 ZR motor is 5 QTS with filter.
    • bj25430
      • Aug 2009
      • 65
      • McAlester, OK
      I have also read that its 4 qts in the manual but it reads no where near the full mark, its just below where the hash marks start where it says "add"?
      • Onevw2go
        • 179
        • Wisconsin
        Do you have the Filter relocation option? that could account for the differance.
        • d_nodixon
          • Sep 2008
          • 475
          • Hammond, LA
          • 2013 SAN 230
          I put 6 qts in my ZR6, not sure what the manual says.
          2013 SAN 230
          2006 SSN 210 (SOLD)
          • bj25430
            • Aug 2009
            • 65
            • McAlester, OK
            I do have the filter relocation to the top and port side of the engine. I read the manual more and it does state that due to the incline of the engine and install that it may be nessasary to add more oil to get it to read full on the dip stick, so i added another qt and its right on now. So i think i have it. I feel i am safe as long as it reads "full" as the manual states it should read. i will check it out on the lake also. Thanks for the input guys and gals, even though i wouldnt let the wife touch the boat, at least the maint. side of it, just like i dont touch the kithen, I'd probably accidently burn the house down if i touched the kitchen. Yellow_Flash_Colorz:
            • steve-o
              • Jul 2009
              • 231
              You checked it on the water, right?
              • AirTool
                • 4049
                • Katy, Texas
                Re: PCM 330 Oil Change, Surely its more than 4QT
                Search for my posts on oil changes.
                AirTool
                • BP22
                  • Jan 2007
                  • 248
                  • Covina, CA
                  • 2006 Super Air Nautique 210
                  I just changed the oil on my 06 210 with the 330. I use a vacuum pump to get out the old oil. Put in 4 quarts and it was reading below the "add" on the dipstick so I added one more quart and she was good to go. If I remember correctly I put in 5 quarts on the last oil change as well.
                  Brandon
                  2006 SAN 210
