Prop seems loose
  • nsteffens
    • Jul 2009
    • 55
    Prop seems loose
    I have a 2002 SAN and when I grab the prop and turn it back and forith, the prop moves ~1/16" side to side without the shaft moving. Is this normal? If it isn't, what can I do to fix it?
  • steve-o
    • Jul 2009
    • 231
    RE: Prop seems loose
    Not normal. Tighten the nut to press the prop back onto the shaft, then loosen the nut to get your pin back in. The prop is press fitted on the shaft and should not move.
    • 8122pbrainard
      • Jul 2007
      • 255
      Please read this thread. http://www.correctcraftfan.com/forum...llation#145077
      the prop is loose!
