Starboard ballast tank won't fill
  • jlbogus
    • Jul 2008
    • 5
    I have an 07 230 and the starboard pump is not working. The light comes on but I do not hear the pump at all. I checked the fuses near the battery switch but was not able to figure out if one had blown or not. I have changed fuses under the dash before but not near the battery switch. I searched the old posts but did not find any where the light was on but the pump was silent. Any ideas? Probably a blown fuse or a blown pump?
    Thank you.
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    RE: Starboard ballast tank won
    Bad impeller maybe, but you should still at least be able to hear the pump a little. Try it with the boat off and the hatch open.
    the WakeSlayer
    1968 Correct Craft Mustang
    • jlbogus
      • Jul 2008
      • 5
      I will give that a try. Any idea if the impeller is covered under the warranties?
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        I doubt it, but they are only ~$20. Just order a pair and keep a spare on hand. Pumpbiz will have them.
        the WakeSlayer
        • jlbogus
          • Jul 2008
          • 5
          Thank you.
          • bchesley
            • Feb 2006
            • 1252
            • Tyler, Texas
            They are covered under warranty. Just call the dealer you bought it from and they should take care of you.
            2001 Super Air Nautique
            Python Powered
            100 Amp Alternator
            Dual Batteries
            Many upgrades coming...
            • AuMDLST
              • Apr 2007
              • 870
              • Orlando, FL (Butler Chain)
              You should have pushbutton reset switches rather than fuses - did you push to reset the ballast button switches located on the panel that indicate 20 amp (I believe)
              2006 SANTE 210 (Pending Sale)
              2005 206 TE (Previous)
              • jlbogus
                • Jul 2008
                • 5
                I do have the push button reset switches and did push them. Now that I think of it, I pushed them and then re-tested with the engine off and engine hatch open and still heard nothing. Probably just a bad pump I would assume.
