knocking at idle in forward
  • natahala
    • Sep 2009
    • 2
    99 Sport GT-40 Seems to be a drive train noise at forward gear idle only. The noise is a knocking sound, as soon as I add a few RPM's it goes away. I was told they all do this?
    RE: knocking at idle in forward
    Check the propeller nut.
    • TRDon
      • Oct 2007
      • 722
      • MN
      At a low rpm, the engine may not smoothly run, meaning it may have a touch of a lope to it. When that happens, the gears in the transmission may knock a touch because of the accelerating and decelerating in essence. Both my 85 and 93 sport dif that and I naver worried about it.
      • steelerguy
        • Jul 2005
        • 86
        Damper Plate. Just changed mine in my 1990 Sport. The noise is he little springs chattering. The Sound was alway at idle and with just a little more RPM it went away. While I was at it I also changed the strut bushings.
        Now she runs smooth and quite.
        • 93nautique0710
          • Aug 2009
          • 173
          • east tn
          • 1993 ski nautique 196
          Re: RE: knocking at idle in forward
          i would start with the dampner plate also or set your idle little higher if its not in specs
