1995 SuperSport
  • workky
    • Nov 2003
    • 120
    • Lake Allatoona
    • Marietta,Ga
    • 1995 SuperSport
    1995 SuperSport
    I got a 1995 SS,it has the GT40 engine,310hp
    There is a canister looking thinggy with 2 wires coming out of the bottom .Fuel flows through this thinggy.It is right before the fuel pump which is mounted on the rear of the engine block,and right after a inline fuel filter.
    I dont have any pictures of it right now
    What is this?If its a fuel seperator ,what do the 2 wires do that go to the bottom of it
    If it is a fuel seperator,were can i get another filter for it
    Thanks for any info
    Oh yea,how many fuel pumps does this boat have,i see one pump(inline)on the back of the block,are there any more?
  • DavidF
    • Sep 2004
    • 611
    • Austin, TX
    RE: 1995 SuperSport
    A GT40 in '95? I thought that PCM was still supplying the TBI engines in '95. Oh well. Anyway, if it is a GT40, there are two fuel pumps: low pressure and high pressure. The low pressure is visible and the high pressure pump is located inside the FCC (Fuel Control Cell). The FCC is a long canister with wires coming out of the TOP. The canister unscrews from the head and located inside is the pump, fuel filter/water seperater.
    You need to provide pictures, things in your description don't add up.
    • Chexi
      • Apr 2025
      • 2119
      • Austin
      • 2000 SAN
      RE: 1995 SuperSport
      Sounds to me like he described the FCC. My understanding is that they are notoriously difficult to unscrew (the first time anyway) and it will require 2 strap wrenches. Search for "Fuel control cell" in this forum.
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        RE: 1995 SuperSport
        I believe in 95 you get the engine both EFI and TBI. I have a friend who has a 95Sn with the GT40 in it.
        the WakeSlayer
        1968 Correct Craft Mustang
        • WakeSlayer
          • Sep 2005
          • 2069
          • Silver Creek, MN
          • 1968 Mustang
          RE: 1995 SuperSport
          ^^"could get" that should say.....^^
          the WakeSlayer
          • workky
            • Nov 2003
            • 120
            • Lake Allatoona
            • Marietta,Ga
            • 1995 SuperSport
            RE: 1995 SuperSport
            My engine is an EFI engine GT40 310 hp,ill try and get a picture of the cainister up,its not very big ,maybe 6inchs tall and 4inches in diam.And has 2 wires going to the bottom of it.The wires do not run together,they are seperated when they get to the bottom of the cannister,it has 1 on 1 side and 1 on the other ,about an inch apart.
            • bchesley
              • Feb 2006
              • 1252
              • Tyler, Texas
              RE: 1995 SuperSport
              Sounds like the low pressure supply pump.
              2001 Super Air Nautique
              Python Powered
              100 Amp Alternator
              Dual Batteries
              Many upgrades coming...
              • xlair
                • 694
                • Wisconsin
                I believe the early GT-40's in 1995 did not have a Fuel Control Cell. It was a different style high pressure pump.
                2001 Pro Air Nautique
                • DavidF
                  • Sep 2004
                  • 611
                  • Austin, TX
                  That is why we need a picture. Not trying to split hairs, just an anal retentative thing I have....A TBI engine is an EFI engine as well. Just like the GT40 is an EFI engine. But, the GT40 engine is not a TBI engine, but rather a MPI engine. I am sorry...ok to ignore me.
