Trailer Height
  • cameraperson
    • Sep 2009
    • 16
    • DC
    Trailer Height
    My trailer hitch seems to be the right height at around 16.5 inches, I wonder what the heights of your hitches are? I am not dragging the rear end, and it seems to be correct. Just checking to see what "normal" is.
    Mike
  • harddock
    • Apr 2008
    • 292
    • toontown E-9
    RE: Trailer Height
    mine needs to be towed slightly nose down to get adequate ground clearance at the prop guard.
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      Re: Trailer Height
      Mike
      Is that with the boat hitched and after driving it a little bit (for the suspension to settle)?
      Previous:
      2011 Super Air Nautique 210
      1994 Sport Nautique
      • SkiTower
        • 2172
        • Clayton, NC
        RE: Re: Trailer Height
        I remember a thread a year or two ago that explained the boat needs to be pulled level. Hitch it to the truck on a level surface and then measure the trailer at the front and rear. Should be within 1". Not sure what my measurement is but the hitch on my F150 is pretty much straight out.
        2007 SV211 SE
        Tow Vehicle 2019 Tundra
        Dealer: www.Whitelake.com
        • bchesley
          • Feb 2006
          • 1252
          • Tyler, Texas
          Its probably a lot more important to pull a tandem level than single axle. You can get away with a little nose down, but nose up you will drag your prop guard.
          2001 Super Air Nautique
          Python Powered
          100 Amp Alternator
          Dual Batteries
          Many upgrades coming...
          • skiinxs
            • 374
            • St. Louis
            • 2019 Ski Nautique 6.2 arriving soon
            Surge brakes work a lot better when the trailer is pulled level. Too much bow down and they will sometimes not release all the way.
            Dave
            16 other Ski Nautiques
            3 MasterCrafts
            18 Ski Supreme's
            1 SlickCraft Squirt Boat
            • CradGen2
              • Aug 2020
              • 1343
              • Horseheads NY
              Skiinxs dude you have owned a boat load of boats. Hollywood is going to get on you about your signature lengh
              • skiinxs
                • 374
                • St. Louis
                Yeah,
                That is exactly the reason I never put one on until now. Just think how much money I would have if that had gone into a 401(k) all these years :grin:
                Dave
                3 MasterCrafts
                18 Ski Supreme's
                • AirTool
                  • 4049
                  • Katy, Texas
                  Re: RE: Re: Trailer Height
                  Originally posted by skiinxs
                  Yeah,
                  Dave
                  You would have about half as much as you did last summer...so enjoy that new 200.
                  • mf01
                    • Jun 2005
                    • 515
                    • Austin, TX
                    RE: Re: RE: Re: Trailer Height
                    My Trailer hitch is at 11" while loaded. The rear of the trailer is about 16". Thank goodness there's a prop guard. I was worried about the slight forward pitch, until last week when I put a 12" scrape in the asphalt.
                    BTW - I have a single axle.
                    Previous:
                    1994 Sport Nautique
                    • skiinxs
                      • 374
                      • St. Louis
                      When you come to a sharp inclune, try to take it on as much as an angle as possible to reduce dragging. Back before prop gaurds were on trailers, you had to learn that or spend a lot of money. Wow I just reread that and it make me sound REALLY old!
                      Dave
                      3 MasterCrafts
                      18 Ski Supreme's
                      • HS
                        • Oct 2007
                        • 1333
                        • Sammamish, WA
                        • 2010 SANTE 210 (Sold)
                        etrailer dot com has good guidelines for setting up the ballmount height.
