Guys I am looking at a 2002 210 to take on a possible trade on my 236 and was wondering how to check the hours in the Perfect pass. The boat has the gauges that tend to reset and I want to have the owner check the hours on the perfect pass as he is not the original owner and is not sure if the hours on the gauge are accurate.
Tags: None
RE: Perfect Pass Hours?
What engine is in the boat? If it is a GM, you'll get a much more reliable reading from the ECU on the engine. You're out of luck with a Ford engine though.
Check the downloads section of this site for the PP manuals. The menus should be easy to find in the manuals.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Re: Perfect Pass Hours?
Originally posted by NautiDave07... I want to have the owner check the hours on the perfect pass ...
Additional PerfectPass features are accessed by pressing the MENU & UP keys together from any main screen. The features available vary depending on the make and model of your boat. If a feature is not present on your PerfectPass then it is not available on your system.
To move to the next feature press the MENU key.
SYSTEM INFO
General system information can be found here. The software version, engine selection, system voltage, system hours, and water temperature (not equipped on all boats) can be found here. NOTE - System Hour and Water Temperature are only available on limited boats
If not in PP and it is a Chevy engine, a dealer should be able to read the hours with a scan tool.
OOPS - Jeff and I are working on a similar response. Great minds think alike.
RE: Re: Perfect Pass Hours?
I wouldn't go by the perfectpass hours, they can be reset to zero with a couple of menu choices.
Dave2019 Ski Nautique 6.2 arriving soon
16 other Ski Nautiques
3 MasterCrafts
18 Ski Supreme's
1 SlickCraft Squirt Boat
