Shower install - couple questions
  • mcbridek
    • 241
    • Raleigh, NC, Lake Gaston NC
    • 06 Ski Nautique 196 SE (2010 - Current) 99 Sport Nautique / GT 40 / FCT (2005 - 2009)
    Not sure if this helps, but on the PCM Engine manual if you go to the back there are water flow diagrams and at least on mine (2006), it shows the places the heater and shower attach. http://www.pcmengines.com/owners_inf...opperation.php
    06 Ski Nautique 196 SE (2010)
    • vr6mole
      • Feb 2009
      • 106
      • Carnegie, PA
      is the pump truly needed?
      We are going to use the shower to just warm up cold wetsuits. won't really be looking for any type of pressure.
      2001 SAN
      • jhiestand
        • 778
        • Columbus, Ohio
        • 08 Super Air 210
        If you don't have a heater installed the pump might not be necessary, although you'd likely need to use larger hose connectors to get much flow at all. With the tiny connectors that come with the shower kits a pump seems like it'd be the only way to get water to travel the distance it needs to.
        '08 Super Air Nautique 210
        • SilentSeven
          • Feb 2014
          • 1861
          • Bellevue WA
          • 2004 Nautique 206
          Does anyone know a source for the T fitting that I need to plumb in the pressure side of the raw water pump?
          Bellevue WA
          • Quinner
            • 2246
            • Correct Crafts
            If you cannot find it at your local Hardware or Home Improvement store, try McMaster Carr
