I have a 1977 Ski Nautique with 351 Ford and Velvet Drive Model AS1-710
Serial Number: 413616. The reverse gear has stopped working. We disconnected the throttle linkage and manually moved the transmission to forward gear which worked but moving it to reverse does nothing. When the throttle linkage is hooked up, putting it in reverse only rev's the engine. I have read some other forums and one suggested that if the boat is over rev'd when backing off the trailer (boat isn't in the water far enough), it can cause damage to the reverse plates in the transmission. About the same time we had an intermittant problem of the starter not wanting to turn the engine over but would if we crossed over the contacts on the neutral safety switch. Not sure if both problems are related but would like suggestions as to what might be causing the reverse not to work. Are these transmissions hard to work on with the help of a car transmission specialist?
