Compression - NonCC Engine
  • TexanC3
    • Apr 2006
    • 66
    • Katy, Texas
    My wife's uncle is looking at getting a replacement engine for his Century Arabian. He found one on evilbay, but the following line has me concerned: "This engine has been compression tested and has seven cylinders that range from 130-135 psi, the eighth cylinder was rated at 115 psi."
    Is this this a deal breaker, and what could it mean down the road as far as repair?
    Here is the engine in question
    http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
    Thanks for your help!!!
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Compression - NonCC Engine
    Your cylinders should be within 10%. It could mean a leaky valve or bad rings. The teat for rings is to put about a teaspoon of oil in the cylinder and repeat the test If the compression comes up its rings and means a rebuild for the engine.
    Nautiqueless in San Diego
      It's a deal breaker. Especially on an engine you cannot physically see and hear run.
      My opinion, the price is way out of line, also.
      • TexanC3
        • Apr 2006
        • 66
        • Katy, Texas
        Thanks guys! Anyone have a suggestion on where to find a replacement engine or have his rebuilt in Texas?
        • JUST-IN-TIME
          • 293
          • ON YOUR BOAT
          compression test on a 4 stroke motor is ok, a leakdown test is the best
          HUMAN BUILT = HUMAN FIXED
          switchbait.com
