1992 Ski Nautigue PCM ProBoss 351 still running hot,,,
  • 1992_Nautique
    • Oct 2009
    • 5
    I've replace the impeller , thermostate, and still running warmer than usual (190). Understand the impeller pieces may be clogging up. I've beentold that the pieces collect in the cooling hose to the transmission.
    What does the line to the transisiion look like?
    Thanks for any help!
  • behindpropellers
    • Apr 2008
    • 97
    • Chippewa Lake, Oh.
    RE: 1992 Ski Nautigue PCM ProBoss 351 still running hot,,,
    Whoever told you that does not know what they are talking about.
    The water comes from the tranny cooler to the RWP. Check the lines that run from your RWP up to the tstat housing.
    You might also be sucking air somewhere in between the bottom strainer and the RWP.
    You might also have a bad ground....what is the temp with nothing on?
    Tim
    • 1992_Nautique
      • Oct 2009
      • 5
      The boat runs cooler without the stat. The gauge appears to be in good operating condition. The RWP line to stat husing is good.
      Is it possible that I have a chuck of old impeller in block?
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        Is it a marine thermostat? Generally speaking 143* for carbed motor, 160* for MPI. If you just went and got a stat from the auto parts store for a ford 351, they would have given you the wrong one.
        the WakeSlayer
        1968 Correct Craft Mustang
        • pdxCC
          • Aug 2009
          • 143
          • Portland, Oregon
          • Current -> 01' Air Nautique Previous - 93' Ski Nautique
          T-Stat for 1993 Ski Nautique
          I just ordered a 160 degree t-stat from skidim for my 93. It is a carburated PCM 5.8 Pro-Boss 351 ford. DId I order the wrong t-stat?
          ____________________________________________
          Current Boat --> 01' Air Nautique (April 12' to current!)
          Previous Boat - 93\' Ski Nautique Closed Bow ( Sept' 09 to March 12')
          • 1992_Nautique
            • Oct 2009
            • 5
            RE: T-Stat for 1993 Ski Nautique
            Got the stat from Whitel lake Marina- marine stat. It is a 143. At 180-190, still to high; right?
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              yes, it is a bit high.
              Have you checked for air leaks? tighten all your hose connections with a 5/16" nut driver. You need to do this at least annually. Also, inspect your strainer for cracks and verify that the O-ring gasket is still there. When you replaced your impeller, was it intact?
              the WakeSlayer
              • 1992_Nautique
                • Oct 2009
                • 5
                Impeller wasd in pretty bad shape but used garden hose to blow out the system. Some pieces must be stuck in the block.
                • darrel409
                  • Jul 2004
                  • 566
                  • San Dimas, So. Cal
                  You're fine pdxcc.
                  • 1992_Nautique
                    • Oct 2009
                    • 5
                    Thanks for all of your feeback. I found the issue,,,loose hoses in tow areas.
                    I did remove most of the hoses and blew out with vacuum cleaner. Found some impeller rubber in some areas.
                    Correcting all of those items final got me to the right heat range.
