Trailer bunk bolts
  • mf01
    • Jun 2005
    • 515
    • Austin, TX
    Trailer bunk bolts
    I plan on replacing the bunks/carpet on the trailer this weekend. The current bunks have bolts in them. I've never seen the top bolt, since it's under the carpet. The bottom looks like a standard nut/washer. Is the top just a counter sunk bolt with washer?
    Previous:
    2011 Super Air Nautique 210
    1994 Sport Nautique
    RE: Trailer bunk bolts
    Yes, just a counter sunk bolt. Probably a carriage bolt, no washer.
    • mf01
      • Jun 2005
      • 515
      • Austin, TX
      So if I buy new carriage bolts, I should be good? I'm trying to get all of the hardware, so my unattended boat is left down at a semi-public dock for the least amount of time. I'd prefer to not run to Home Depot during the process, but might have to.
      Previous:
      1994 Sport Nautique
      • AirTool
        • 4049
        • Katy, Texas
        Do you know anybody at McQueeny you could borrow a trailer from? There are hundreds parked outside the ski club and neighborhood there.
        • mf01
          • Jun 2005
          • 515
          • Austin, TX
          Nope, I'm mainly on Lake Austin. I plan on tying the boat up at a neighborhood ramp/dock, then swap out the bunks at a friends house a few blocks away.
          Previous:
          1994 Sport Nautique
          • 81nautique
            • Feb 2006
            • 257
            • Big Rock, Illinois
            • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
            Be prepared with a sawzall to cut the old ones off. You could fight with those old rusted bolts all day.
            • mf01
              • Jun 2005
              • 515
              • Austin, TX
              I plan on bringing a grinder. I put some PB blaster on them tonight and will again tomorrow.
              Previous:
              1994 Sport Nautique
              • 81nautique
                • Feb 2006
                • 257
                I think what you'll find is that the bolts will just spin and being countersunk into the bunks you'll have a hard time gripping them. The grinder makes a lot of heat and you'll start burning the old bunks. Cutting is easier but either will work.
                • RainDog
                  • Jan 2008
                  • 64
                  • Wauwatosa/Green Lake WI
                  • 1962 Classic 2002 SAN -Python Powered-
                  A cold chisel and 2 whacks with a hammer sheared every bolt easily on the 1978 trailer I restored. Place the chisel between the nut and underside of the trailer rail.
                  1962 Classic
                  2002 Super Air -Python Powered-
                  Many more to come....
                  • 81nautique
                    • Feb 2006
                    • 257
                    Re: RE: Trailer bunk bolts
                    Show Off!!! :razz:
                    • mf01
                      • Jun 2005
                      • 515
                      • Austin, TX
                      RE: Re: RE: Trailer bunk bolts
                      I thought about just re carpeting the current bunks, but I thought it'd be easier and better to just replace them. Now I'm thinking it might be a pain to replace the bunks.
                      Previous:
                      1994 Sport Nautique
                      • behindpropellers
                        • Apr 2008
                        • 97
                        • Chippewa Lake, Oh.
                        Re: RE: Re: RE: Trailer bunk bolts
                        Might want to pull them off. Mine were severly pitted under the bunks.
                        My '86 trailer had SS carriage bolts in them.
                        • skijones
                          • Mar 2005
                          • 235
                          • COLUMBUS OH
                          • 1985 2001 1999 Snob
                          RE: Re: RE: Re: RE: Trailer bunk bolts
                          My 89 eagle trailer has 1" lag bolts put in from the bottom. Replaced the bunks and carpet 2 years ago and no problems yet.
                          • east tx skier
                            • 1561
                            • Tyler, TX
                            When you replace those carriage bolts, skip the nylock nuts and double up on regular stainless steel nuts and lock washers. The nylock nuts will just require that you hold the bolt on the threaded end to keep it from spinning inside the bunk. Double up the nuts and they'll stay put.
                            • mf01
                              • Jun 2005
                              • 515
                              • Austin, TX
                              Re: RE: Re: RE: Re: RE: Trailer bunk bolts
                              Thanks for the tip. Should I use some loctite? So lock washers instead of regular washers?
                              Previous:
                              1994 Sport Nautique
