Removal of impeller - help
  • Flipside
    • Feb 2009
    • 137
    • Portland, OR
    In order to remove the impeller on a PCM EX343 (2009) do you have to loosen the belt tensioner, and remove the housing to the raw water pump housing?
  • ClemsonDave
    • Oct 2004
    • 659
    • Glen Allen, VA
    • Ski Nautique 200
    RE: Removal of impeller - help
    Loosen tensioner
    Remove belt
    Remove pulley on water pump (three allen bolts)
    Remove water pump cover (three hex bolts)
    Promo Team member
    1999 196
    2010 200 Team 2010 200 Team
    2011 200 Team 2011 200 Team
    2012 200 Team - 2012 200 Team
    2013 200 Team - 2013 200 Team
    2014 200 Team - 2014 200 Team
    2015 200 Team - on the way
    • AirTool
      • 4049
      • Katy, Texas
      Re: RE: Removal of impeller - help
      Originally posted by ClemsonDave
      Loosen tensioner
      Remove belt
      Don't remove the Pulley! just stick your (8 mm?) socket and extension through the pulley to get to the cover bolts. See pic I already posted. Better pic available tonight if you can wait...PM me flipside.
      I was going to post a photo how to of this but I'm missing one picture because IT STARTED POURING DOWN RAIN plus my camera battery died. Note it hadn't rained for at least two months prior...then decides to pour on my 10 minute impeller project. Would have been 5 without the camera.
      • AirTool
        • 4049
        • Katy, Texas
        Originally posted by AirTool
        Just stick your (8 mm?) socket and extension through the pulley to get to the cover bolts.
        • ClemsonDave
          • Oct 2004
          • 659
          • Glen Allen, VA
          • Ski Nautique 200
          I guess I wasted a whole 15 seconds doing that. Yellow_Flash_Colorz:
          I thought it would be easier to put it back on without having to line up the water pump bolts with the pulley holes. Either way works.
          Promo Team member
          1999 196
          • AirTool
            • 4049
            • Katy, Texas
            Not a big deal. I guess the bigger risks are that one drops an allen bolt down in the bildge and spends a while fishing it out. Bigger risk is that a newbie crossthreads one of the allen bolts and then has to buy a new pump cover or pump.
            I love taking things apart. But on this one, I'll stick to the grease monkey philosphy, "Don't take no **** off you don't have to." Especially if you are doing it on the water.
            • AirTool
              • 4049
              • Katy, Texas
              Correction - 10 mm socket.
