Replacing Alternator belt on GT 40
  • Bryand82487
    • Mar 2009
    • 74
    • Tennessee
    I'm headed out this afternoon to replace my alternator belt on my 2000 SAN. Can anyone give me some advice on how to and what tools I may need?
  • east tx skier
    • 1561
    • Tyler, TX
    RE: Replacing Alternator belt on GT 40
    A wrench or socket set and you're good to go.
    • Bryand82487
      • Mar 2009
      • 74
      • Tennessee
      Thanks! Hopefully all goes well.
      • SNobsessed
        • Nov 2008
        • 60
        Bryan - Be careful how much you tension the belt. Too much tension will fail the bearing. It should have about 1/2 inch of deflection between pulleys with heavy thumb pressure. On the other extreme, check to see it is tight enough by putting a socket wrench on the alternator pulley nut & make sure you can't slip it against the belt.
        Good luck
        • Bryand82487
          • Mar 2009
          • 74
          • Tennessee
          Belt replacement went smoothly. Thanks for the help guys!
